This command disables and deletes the specified IS-IS router process in the current virtual router.
| all | Deletes all IS-IS router processes. |
| area_name | Specifies the name of the IS-IS router process to be deleted. |
None.
All configuration for the specified router is lost. All routes learned from this router process are purged from the routing tables.
The following command deletes the IS-IS process named areax:
delete isis area areax
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
